I have been attempting to setup alerting with dyanamic notifications with prometheus alertmanager. I spent the last two days thinking I was doing something wrong, I could not see the severity field in the incident payload. The urgency would be set correctly if I set the severity under the pagerduty_config to ‘critical’, but I never saw the severity field in the incident message payload.
I then set the severity in the pagerduty_config to ‘warning’ and the incident showed up with a ‘Low’ urgency, so clearly the pagerduty_config severity field is being considered in the code logic when generating the pagerduty incident. However, I still do not see the severity field in the incident’s message payload.
Is this expected?
For references see below
# alertmanager configuration YAML
receivers:
- name: default-receiver
- name: pagerduty
pagerduty_configs:
- description: '[{{ .Status | toUpper }}{{ if eq .Status "firing" }}:{{ .Alerts.Firing
| len }}{{ end }}] {{ .CommonAnnotations.summary }}'
routing_key: KEY
severity: 'info'
route:
group_interval: 5m
group_wait: 10s
receiver: default-receiver
repeat_interval: 3h
routes:
- matchers:
- team = sre
receiver: pagerduty
# the generated incident payload
"client": "Alertmanager",
"client_url": "http://prometheus-alertmanager-0:9093/#/alerts?receiver=pagerduty",
"contexts": null,
"description": "[FIRING:1] Spark Operator available replicas is not the same as desired replicas.",
"event_type": "trigger",
"incident_key": "KEY",
"service_key": "KEY",
"details": {
"firing": "Labels:
- alertname = SparkOperatorDown
- app_kubernetes_io_component = metrics
- app_kubernetes_io_instance = prometheus
- app_kubernetes_io_managed_by = Helm
- app_kubernetes_io_name = kube-state-metrics
- app_kubernetes_io_part_of = kube-state-metrics
- app_kubernetes_io_version = 2.8.0
- cluster = CLUSTERNAME
- deployment = spark-spark-operator
- helm_sh_chart = kube-state-metrics-4.30.0
- instance =IP:PORT
- job = kubernetes-service-endpoints
- namespace = spark-operator
- node = NODE
- service = prometheus-kube-state-metrics
- severity = page
- team = sre
Annotations:
- summary = Spark Operator available replicas is not the same as desired replicas.
Source: http://prometheus-server-8577d64b5d-4hbhz:9090/graph?g0.expr=kube_deployment_status_replicas_available%7Bdeployment%3D%22spark-spark-operator%22%2Cnamespace%3D%22spark-operator%22%7D+%2F+kube_deployment_status_replicas%7Bdeployment%3D%22spark-spark-operator%22%2Cnamespace%3D%22spark-operator%22%7D+%21%3D+1&g0.tab=1
"num_firing": "1",
"num_resolved": "0",
"resolved": ""
